Nuisance calls!
Pawsitivity
Nuisance calls!
On my goodness, I've been a Plusnet customer for a couple of weeks the number of nuisance calls to me are INSANE. I've been on the TPS for years with no problems. Why is this happening?????? 😡
7 REPLIES 7
198kHz
Fixes: 41
Re: Nuisance calls!
Do you have the same number, or did it change when you came to Plusnet?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Pawsitivity
Re: Nuisance calls!
Same number for years
Tags (1)
BrightonRock
Fixes: 7
Re: Nuisance calls!
Have you considered Plusnet Call Protect? It is free. You can set it up yourself in "Your Account" on the website.Home > My Perks > Call Features
Pawsitivity
Re: Nuisance calls!
Yes, but I just couldn't work my way around the website, it just took me round and round in circles, it was really hard to use so just thought I was on the wrong track
BrightonRock
Fixes: 7
Re: Nuisance calls!
Have you found your way there now? I gave you the route in my first post.
I agree it well hidden; it took me about 5 - 10  minutes to find the route even though I knew the general area to look.. .Somewhere on the website - although I have never found it - there is also claimed to be the attached guidance.
Pawsitivity
Re: Nuisance calls!
I'm trying now.
It has to be activated - thank you for the guide there.
Sadly 1572 doesn't seem to work on my phone?
BrightonRock
Fixes: 7
Re: Nuisance calls!
Give it 24 hours
