Non-geographic numbers
DorsetDave
15 REPLIES 15
DorsetDave
Re: Non-geographic numbers
I have the Anytime package which I am told that 0845 and 0871 calls are inclusive at all times. I would like to know if this includes 0844 and 0871 calls as well. Thanks
Oldjim
Fixes: 63
it doesn't include 0844 or 0871 as that is a premium rate number
0845 and 0870 are included
Anoush
Aspiring Hero
Fixes: 139
A warm welcome to the forums @DorsetDave
As Oldjim has advised, 0871 and 0844 are premium rate numbers. They are not included in any call plan. 0870 and 0845 numbers are included, but only up to 60 minutes per call.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
DorsetDave
Many thanks for the replies. It wasn't clear to me but now it is, but its generally confusing for people overall with 084 and 087 numbers. I feel the regulator needs to clarify the situation.
Incidentally I tried to use chat and phone support but there was a long waiting time so the Forum was very useful. I only joined Plusnet in July after seeing good reports especially about customer support. Unfortunately Plusnet seems to be a victim of its own success in this regard as I have met people saying the waiting times can be often quite long.
Mav
Fixes: 512
Moderator's note by Mike (Mav): I have changed the fix to Oldjim as he was the first to give the answer in message #3.
Forum Moderator and Customer
derbyjon
I understand that 0871 & 0844 numbers are premium and therefore incur a service charge from the service provider which will be passed on as a charge to the telephone account.
However, shouldn't the PlusNet access charge of 9.58p/min be included in calling packages?
spraxyt
Aspiring Legend
Fixes: 75
No because they are calls to premium rate numbers and charges related to such numbers are not included in any call plans.
David
derbyjon
Hmm. Sounds like a convenient opportunity to cash-in, assuming there's no difference in cost to PlusNet of arranging a connection to an 0844 number compared with an 0845 number.
Regardless, thanks for the clarification.
pjmarsh
Fixes: 20
@derbyjon, there is a higher cost to Plusnet for calls to those numbers.  You can get an income from owning an 0844 or 0871 number (if your provider passes that on to you).
derbyjon
Isn't that income the separate service charge though?
As an example, I called an 0844640xxxx number for 1 minute 9 seconds (so a 2 minute billable call). That number type carries a service charge of 1p/min.
(From magenta: Charge Code: SC002 1p/min + Acc Charge)
I was billed 21p for the call, which I assume is PlusNet's access charge of 19p plus the service charge of 2p.
The income to the service provider is just that 2p to my understanding.
pjmarsh
Fixes: 20
Quite possibly.  It's been a while since I've looked at it.  I'm not aware (though haven't done much research into it) of any provider who have the access charge included in any allowances.
derbyjon
You are probably correct in all providers failing to include it in their package allowances.
That's what's known as price collusion isn't it? Wink
PeeGee
The clue is in the wording, with the reference of "calls to" specific numbers. As such, it covers all elements of charges resulting from a "call to" a number.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
CJT-80
Fixes: 4
At one time a certain "Virginal" provider (I am sure you get the reference) did include calls (limited by a set number of minutes) to ALL 084/087 numbers including 0843/4 and 0871/2 numbers.  But they stopped offering the plan when the moved to 4G
Sad
Kind Regards,
CJT
