Noisy line
diydel
Noisy line
Hi All
I have interference on my line, i have now tried a new handset directly into test socket on master and problem solved. Reinstall face-plate, still Ok however when i plug the router back in and it connects to broadband the interference returns.
Anyone had similar or know how to solve this.
Thanks Derek
5 REPLIES 5
Anoush
Aspiring Hero
Fixes: 139
Re: Noisy line
A warm welcome to the forums @diydel
The issue you're describing usually indicates a fault with the router, microfilter or the exchange. If you've tried an alternative filter/router I'd recommend raising this as a fault to us here to look into further.
I hope this helps
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
diydel
Re: Noisy line
Hi
Thanks for replying. There is no filter, believe this is all in the face-plate as installed by Bt (one socket for phone, one for broadband). Unfortunately don't have an alternative router to check. Line check on-line comes up with oops-there was an error and asks to to call
Anoush
Aspiring Hero
Fixes: 139
Re: Noisy line
It's possibly not a line issue if your home phone is clear and working with no equipment attached. If you complete the broadband troubleshooter at http://faults.plus.net this will allow you to raise a fault online where our broadband faults team will pick it up and contact you.
diydel
Re: Noisy line
Hi
Apologies for slow reply. However when i do the broadband checker it says the fault is with phone line and closes ticket.
NB. After trying to run phone line checker my broadband goes down.
Regards
Derek
Anoush
Aspiring Hero
Fixes: 139
Re: Noisy line
I would recommend completing the broadband fault checker selecting the option that your phone line is clear.
At the last step of the process, you'll be asked to leave any additional notes where you can advise us the noise only occurs when the router is plugged in.
I hope this helps
