Noisy line
- Home Phone
- Re: Noisy line
Noisy line
08-03-2016 3:53 PM
outside my house contractors are replacing kerbs for new cycleway
Anyhow i have noticed today i have now a crackly line on phone , could someone check my phone line , Phne call wait is LONG , chat says 6 waiting
so thought easierr t ask here some kind PN staff could check
Ps also tried new Help page got some weird unhelpful answer
Message 1 of 8
(2,099 Views)
7 REPLIES 7
Re: Noisy line
08-03-2016 3:59 PM
The test isn't finding a fault on your line unfortunately. I've left a ticket on your account with some checks to go through before we proceed further. Once you've gone through the checks and respond to the ticket, our faults team will get an engineer booked for you
In regards to the help page, I think I flagged that exact issue up a few days ago
Message 2 of 8
(945 Views)
Re: Noisy line
08-03-2016 6:03 PM
Cheers Harry , just done the quiet line test and still crackles
Message 3 of 8
(945 Views)
Re: Noisy line
09-03-2016 9:51 AM
In that case, can you respond to the ticket confirming you've carried out the checks and agree to the charge if the fault is found to be with your equipment/internal wiring and we'll get that progressed for you.
Message 4 of 8
(945 Views)
Re: Noisy line
09-03-2016 4:22 PM
Harry , just to confirm on my open ticket .
I have just borrowed a corded phone which gives me same interference on quiet line test 17070
as for internal wiring ,, I have non everything is direct into socket . phone and fibre
Message 5 of 8
(945 Views)
Re: Noisy line
09-03-2016 4:38 PM
Could you respond to the ticket confirming the following please:
Once you've done this, we'll be able to proceed with booking an engineer for you.
Thanks.
Quote If you wish to proceed with an engineer appointment we need the following information:
* Agreement that if the issue is caused by any of the above that you may receive a £50 charge.
* An alternative contact number preferably a mobile
* Availability should an engineer need to attend the premises, between the hours of 8am-1pm & 1pm-6pm Monday - Friday.
Thanks.
Message 6 of 8
(945 Views)
Re: Noisy line
14-03-2016 10:04 AM
HarryB , BT engineer has been , No fault found noise has disappeared , suggested its possible a joint has water ingress and as weather has been warm it has dried out and fixed itself
said to ring again if it comes back
Message 7 of 8
(945 Views)
Re: Noisy line
14-03-2016 11:02 AM
Message 8 of 8
(945 Views)
