Noisy line with broadband disconnects
- Home Phone
- Noisy line with broadband disconnects
18-01-2018 4:32 PM
After a decade of troublefree use my phone line has suddenly become extremely noisy, accompanied by periodic broadband disconnects. Plugging the phone directly into the master socket does not improve matters. Reporting this as a phone fault, thereby generating a Plusnet line check, immediately leads to a broadband disconnect, and thus I’m back to square one. How do I progress this please?
Re: Noisy line with broadband disconnects
18-01-2018 5:30 PM
Noise on the line is result of fault conditions on the pair,
and that is not compatible with broadband.
Your always better using the master socket,
and if the engineer finds a fault on extension wiring then charges will be payable.
on
18-01-2018
7:59 PM
- last edited on
19-01-2018
7:33 AM
by
Mav
'Noise on the line is result of fault conditions on the pair'
Thanks but what's 'the pair'?
'if the engineer finds a fault on extension wiring then charges will be payable'
I don't care about that, but how do I get 'the engineer', given that the procedure apparently involves a line check in the first instance – which immediately disconnects the broadband? In this scenario what is the system for reporting the fault without starting a line check? I firmly believe the problem is nothing to do with internal wiring.
Moderator's note by Mike (Mav): Quote fixed.
18-01-2018 8:20 PM
Have a look on the Help Pages scroll down to the "Still need help" and it should give you links to "Chat" or call :
Customer support
- 0800 432 0200 (from within in the UK)
- +44 345 140 0200 (from abroad)
7.30am - 10pm, every day Please have your username and password handy.
18-01-2018 9:52 PM
The pair is the name of the a and b legs, ie the phone line wires,
hence "pair"
If the fault is in your house the charge is likely to be £130 to £160 to disconnect the internal wires.
18-01-2018 9:55 PM
During line testing the TAM is operated to test the line.
The TAM is connected to the test head in the telephone exchange.
18-01-2018 9:59 PM
@harrow PN charge £65 in those circumstances, before sending an engineer they would want the customer to do as many checks to eliminate the possibility of a domestic problem.
18-01-2018 10:06 PM
Good if it is £65 but that is £65 that can be easily avoided.
BT have certainly been charging £130 and have seen £160 recently to disconnect internal extensions.
19-01-2018 1:41 PM
Welcome to the community forums @ajax
I'm sorry to hear your phone line is noisy and your broadband connection intermittent
Our tests aren't finding the cause of the issue, so I've raised this ticket on your account with steps you can take to progress this as a fault. I hope this helps.
24-01-2018 11:32 AM
24-01-2018 2:00 PM
Thanks for getting back to us @ajax
I'm sorry to hear the suggestions didn't help. Our faults team generally pick up a ticket within 72 hours, but I'll take a look now instead. I'll book an engineer appointment for you and I'll update the ticket soon.
24-01-2018 2:07 PM
It looks like our tests are now showing an external fault so I've raised this with Openreach and I've also updated you by e-mail and text message with more info. Hope this helps.
- Home Phone
