Noisy Line
- Home Phone
- Noisy Line
Noisy Line
19-01-2015 9:39 PM
I initially thought the phone itself may have been at fault so replaced all the equipment (new phone, cable and microfilter) but the problem persists. I have tried all the phone lines in the house and the test socket but the outcome is always the same.
Re: Noisy Line
19-01-2015 10:27 PM
Re: Noisy Line
20-01-2015 9:25 AM
Re: Noisy Line
23-01-2015 9:24 AM
Could you look into this again please? Many thanks.
Re: Noisy Line
23-01-2015 9:35 AM
From looking at the details it's a common fault affecting multiple lines in your area.
It looks like we should have a further update today but it appears to be a complex issue that involves temporary traffic lights so Openreach can get at the cables.
As soon as we know more our faults team will be in touch.
Re: Noisy Line
25-01-2015 1:40 PM
My internet connection is now suffering badly, disconnecting and reconnecting every minute or so. Really not happy as I have now been without phone for over a week and now have a useless internet connection. I'm aware that this is out of your control as you are relying on OR to fix the problem but presumably there will be a forthcoming offer of compensation for this loss of service?
Many Thanks.
Re: Noisy Line
26-01-2015 9:56 AM
I would like to make sure that you are back up and running first. It looks like our suppliers are still working on getting this fault resolved. Apologies that this is causing hassle.
Matty
Re: Noisy Line
31-01-2015 10:56 AM
No internet at all now. Phone rings but won't answer if picked up.
Re: Noisy Line
31-01-2015 11:53 AM
@Addz27
I have taken a look into whats going on and I would like to refer you to a ticket on your account
https://www.plus.net/wizard/?p=view_question&id=ticket_id=97997501
Re: Noisy Line
03-02-2015 3:43 PM
Would you be able to confirm if this is the case?
Re: Noisy Line
04-02-2015 9:16 AM
