No phone
Sparker74
No phone
Not sure if in right place but landline phone not working again have reported it but it's nearly a week , last time it took nearly three weeks to fix and three different engineers...anyone else had to wait so long?.thankfully my internet is still working...
9 REPLIES 9
RandallFlagg
Fixes: 75
Re: No phone
Hi @Sparker74
Thanks for getting in touch.
Sorry to hear that this is taking longer than expected.
Do you have a fault ticket reference so that we can update you on the progress of the fault?
Best wishes,
Dave
198kHz
Fixes: 41
Re: No phone
Possibly it's a fault which requires extensive underground work, or there's some other delay.
It may be that BTOR have handed it back to Plusnet as cleared when in fact it's not - it does happen.  Shocked
You can check your tickets here -
https://www.plus.net/wizard/index.html?p=search
Edit: @RandallFlagg types faster than me.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Sparker74
Re: No phone
Hi
Thanks for the reply I  do have this number
TR0000009413305
Is this the right number?..
Sparker74
Re: No phone
Ok thanks will check...I do appreciate that some problems can take longer to sort ...😊
EmilyD
Fixes: 117
Re: No phone
Hi @Sparker74,
Thank you for sending the fault reference over. I've had a look into this now and have been able to get an update on this for you. As this is account specific information I've added this to the fault ticket on your account - you can view this here.
 Emily D
Sparker74
Re: No phone
Hi engineer did fix phone yesterday afternoon and all was fine until this morning..have no dial tone so phone off again...what is going on?..
JOLO
Fixes: 77
Re: No phone
Hi @Sparker74,
I've checked the phone fault. I've added the engineer notes to the ticket on your account.
I retested the line and it was coming back clear but as you're still having issues we'll have to book an engineer for another visit, unfortunately.
Checking the appointment book for your fault just now the earliest appointment showing is Tuesday AM/PM slot and then every weekday following that. Can you let me know which of those slots/days would be best for you to book in. In the meantime if you need us to add a call divert feature to your line (so that if anyone dials the number the call is diverted to a working line) then please let us know by private messaging one of the staff or by updating the ticket on the account.
I've checked the broadband service and this does appear to be working, but I've put a reset on the line as the SNR was too low, probably causing you some speed problems.
From your comments on this post and the history of the account this appears to be an ongoing issue that keeps recurring every 4 or 5 months, because of this I'm going to move the ticket on the account to be managed by us in Social Media for you.
Fixes: 160
Re: No phone
Will that be FOC as is offered by BT Retail when a line is down, or will the user be charged the cost of diverted call?
If there is no dial tone, then that would imply that at least one leg of the pair is disconnected.  With just one leg connected, broadband can limp along but speed will not be great.  Raising the SNRM might improve stability, but it will reduce the synch rate … it is though just possible that if the error rate at present is substantial and this change brings about a marked improvement, the effective data speed might be improved.
Until the phone line is repaired, there is little point trying to fix a broadband performance issue.
Jubby
All Star
Fixes: 31
Re: No phone
Hi @Sparker74
After checking your ticket I can see you have confirmed the dial tone has returned.
I have retested the service and we are no longer able to detect a fault the connection appears stable and the speed is between the estimates.
Due to no fault currently occurring, it is not recommend to send an engineer as no fault would be detected. Please continue to monitor your service and at the first sign of an issue let us know so we can continue to investigate.
@Townman
The TCD (Temporary Call Divert) feature is a free service when a fault is raised however, the calls made from the line to the diverted number are chargeable. If you have a call plan some or all call charges may not be applicable dependant on the product for example Unlimited UK & Mobile calls would rule out all UK mobile and UK land-line call charges.
 Lewis G
 Infrastructure Operations Professional
