No phone ticket #83549501
- Home Phone
- No phone ticket #83549501
- « Previous
- 1
- 2
- Next »
Re: No phone ticket #83549501
04-04-2014 12:10 PM
THIS SITUATION IS TOTALLY UNACCEPTABLE.
04-04-2014 12:38 PM
requires second stag e to open 500 pr joi nt in manhole 67 by library on junction of bye street and ho mend have measured l oop to manhole requi res proving either i n joint or length to next manhole outsid e bank no good spare s all faulty also
Translating, this one is still in hand with BTOR as a priority fault for the underground work but unfortunately there's not much that we can do to push it faster than it's already going and there are no spare cables to swap you onto.
I know that you're not happy with the service you've received and I'm genuinely sorry for that, but unfortunately there are times when we're not able to meet a customer's expectations - especially when it concerns repair work which is outside of our control. Five days is a long time to be without service and there won't be any problem refunding you for the downtime - just give us a nudge when you're happy with the performance and we'll get that done for you.
04-04-2014 2:35 PM
Thanks for the update. I appreciate you have now done all that you can reasonably be expected to do - which is all I ask as a customer. Please ensure you continue to press OpenReach as far as you are able and keep me informed of any progress. I am not hopeful of any quick resolution given the information in the engineer notes, but there is nothing much that I can do about that. Thank you.
06-04-2014 4:42 PM
07-04-2014 9:52 AM
Edit: As per my colleague's update on your ticket, a 5-pair cable needs to be replaced which isn't something an engineer can 'just do' on a typical repair job. The last engineer has submitted an A55 which is the form needed to get the BT planners to determine what needs replacing, how long, where it should connect to, etc.. This has a 5 working day lead time so hopefully we will see progress towards the end of the week. Once this form has been approved, an engineer will be tasked to go out and make the repair which should resolve your issues.
My colleagues in the faults team will continue to monitor this and update you via the ticket online.
07-04-2014 12:01 PM
07-04-2014 1:11 PM
I'll check your fault ticket later in the week and the faults team will also pick up any updates for you too, hopefully this is a simple cable swap that shouldn't take too long - fingers are crossed!
08-04-2014 3:21 PM
17-04-2014 4:24 PM
Ben - can you take a look at my ticket - suffice to say the response from customer service has not been sufficient - i would be obliged if you were look into it! Also my upload speed as reverted to the capped rate 448 - can it be uncapped again please.
20-04-2014 1:28 PM
20-04-2014 1:36 PM
The DCT team only cover the forums on working days during normal office hours, so don't hope for an authoritative response before Tuesday.
Ultimately you and PN are in the hands of BTOR. If there are no spare pairs, then new cables need to be pulled through. I saw a BTOR van out working this morning (Sunday) which was surprising, as I can imagine they would like to be at home with their families this Easter, just like you and I.
22-04-2014 11:25 AM
I think and hope that everything will then be closed off?
22-04-2014 11:40 AM
I've just added the discount that you agreed to on Ticket: 83549501
I'll perform an SNR reset as well to uncap your upstream. This should take effect shortly. You may need to disconnect and re-connect your router.
30-04-2014 3:48 PM
- « Previous
- 1
- 2
- Next »
