No phone/broadband for a week
fourtracker80
Hi there
I raised a ticket regarding no dial tone and have been struggling to get a response/update. An Openreach engineer called on Friday to say they’d fixed one problem and found another (or words to that effect) but I’ve had nothing from Plusnet regarding it taking longer than the normal 1-3 days (which you said in the ticket you would) and no idea whether I need to be at home for a day for an engineer to visit.
Would really appreciate an update on what’s going on. Am unable to work from home while the line is down, so it’s starting to cause real issues now.
Mark
5 REPLIES 5
Fixes: 1,600
Re: No phone/broadband for a week
Hi Mark.
I'm sorry that you're having issues with your line and for the lack of timely updates.
Engineer notes essentially say what you know that a fault was fixed, but they found another so they sent the fault report back to us to book an appointment with you for further investigation, but due to the length of time it's been, the fault report has closed down on our suppliers systems. Sad
To progress this we need to raise a new fault report, but as testing the line is showing an external fault(The same issue we detected when we originally raised the fault), it's safe to assume that the next engineer who goes out will likely need access to your property, so to try to avoid further delay I've contacted our suppliers and asked them to send the required activity on the fault report for us to be able to book an appointment with you.
Before we do book an appointment, can you confirm you've tried the steps Here to bypass any internal wiring which may be affecting this? Failing that, could you reply to this ticket with your availability for a visit please?
Feel free to drop us a reply back here to give us a nudge once you've done so and we'll be happy to get the appointment booked in for you.
Apologies for the inconvenience caused by this problem.
Anoush
[edit]
In the meantime, I've raised a broadband fault with our suppliers as our tests are also showing a fault at the cabinet(The green box in the road), as a different type of engineer may be able to diagnose the issue without access to your property.
fourtracker80
Thanks again Anoush, I’ve replied to the ticket
Mark
Fixes: 1,600
No worries Mark.
Appointment is booked in for this Thursday morning.
Let us know how it goes.
fourtracker80
Hi Anoush
Just to confirm, the engineer has been and the phone and broadband are up and running again. Internet is around 10Mbps but I assume will work its way back up to the previous levels in time.
Thanks again
Mark
adamwalker
Fixes: 221
Thanks a lot for letting us know, that's really good to see. I've just replied on your account to confirm a refund for the time without service.
 Adam Walker
