No landline but broadband ok
- Home Phone
- Re: No landline but broadband ok
08-02-2013 5:47 PM
Hi
My landline stopped working a few weeks ago, I noticed on the 1st feb when relatives txted me. Plusnet said the fault was identified on Openreaches bit of the exchange and would be solved by 6th Feb. It wasnt and the ticket is still open. i notice there are LOADS of people on forums with this problem, has anyone ever had it solved?
Despondently
Laurie
Despondently
Laurie
Message 1 of 7
(2,420 Views)
6 REPLIES 6
08-02-2013 9:51 PM
Unfortunately the PN staff don't usual patrol the forum over the weekend and will probably pick this up on monday for you, probably the best solution is to give them a call.
current waiting times can be found here http://www.plus.net/supportpages.html?a=212
Message 2 of 7
(729 Views)
09-02-2013 4:23 AM
We had a similar problem with BT phone and broadband about 5 months ago. We reported the line to BT as an engineering fault via their web site. When the BT Open Reach engineer visited he tracked the cause of the problem down to a broken connection on one of the copper conductor pair in the wire feeding our house, The problem was in the street some distance from the house. Apparently DSL broadband can work on a single connector, but the modern voice phone system needs a pair of conductors.
Now Zen, but a +Net residue.
Message 3 of 7
(729 Views)
09-02-2013 5:55 PM
:)Ah, thanks for the replies folks! I hope its something like that. Will ring if no joy by Monday evening, lucky I have my mobile but much more expensive!
Laurie
Laurie
Message 4 of 7
(729 Views)
10-02-2013 2:26 PM
Aha, Plusnet replied to say that an engineer did try to fix the fault on the 7th but couldnt because it was too much for him. They will be sending another (better?) engineer in a few days.
Hmm...
Hmm...
Message 5 of 7
(729 Views)
13-02-2013 6:24 PM
And hmm... it is! End of day when second engineer was supposed to have a go but still no phone. Broadband working extremely well - to compensate perhaps?
Message 6 of 7
(729 Views)
14-02-2013 5:17 PM
Glad to hear that your broadband is working but not the case with your phone line, your ticket has been updated regarding this. We've escalated this to get is resolved ASAP,
you can view the update at https://portal.plus.net/wizard/?p=search
Chris
Chris
Message 7 of 7
(729 Views)
- Home Phone
