No dialtone
melyn
No dialtone
  1. I get dialtone when I plug my phone  into my house's master socket.
  2. I also get dialtone when I plug in the filter and just the phone.
  3. But as soon as I plug my broadband router into the filter too, I lose dialtone.
I'm asking this community because Plusnet has a 30 minute wait for phone help just now, chat is closed, and I can't see a way to raise a support ticket. Not great customer support from them.
Hope you don't mind me asking you here.
9 REPLIES 9
Mustrum
Fixes: 77
Re: No dialtone
Do you have another filter and/or router you can try?
Fixes: 1,600
Re: No dialtone
Hi there and welcome to the community.
It sounds like there’s a problem with either the router, or the equipment at the exchange.
I’d first run a line test here: https://www.plus.net/my-account/tools/phone-troubleshooter/ and see if it picks up any issues.
Let us know how it goes.
melyn
Re: No dialtone
Thanks for your reply Mustrum. I get the same result with two different filters.
Fixes: 1,600
Re: No dialtone
Testing your line is detecting a loop condition which is basically a short circuit somewhere.
Can you plug your router into the test socket as explained below?
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Scrap that. If your phone handset works without your router then it's possibly not going to be an internal wiring issue. Do you have a different router you could try?
melyn
Re: No dialtone
Thanks Gandalf. I'm sorry, I don't have a different spare router to try.
Fixes: 1,600
Re: No dialtone
It's probably worth trying a different router. If you'd like a replacement through us, I'd recommend getting in touch with Customer Options on 0800 013 2632 and we'll see what we can do.
Alternatively, we can arrange an engineer visit to further investigate the problem.
Let us me know if you want to go ahead with the visit and I'll get the ball rolling.
Fixes: 1,600
Re: No dialtone
Hello there.
I'm just following up here and curious as to whether you've got this resolved yet?
melyn
Re: No dialtone
Just back from a trip. No it's still not working Gandalf. Please could an engineer be sent, or a router swap? Thanks, Gareth
198kHz
Fixes: 41
Re: No dialtone
If you're getting dial tone from the master socket, the problem must be in your property. Worth persevering, then, as an engineer visit is going to cost!
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
