No dial tone
- Home Phone
- No dial tone
No dial tone
04-01-2012 8:19 PM
I'm having a bit of a problem with my phone, my internet is still working fine but my home phone no longer has a dial tone and won't ring out although
people say they have tried ringing me, and that my phone is ringing!
Message 1 of 7
(1,860 Views)
6 REPLIES 6
Re: No dial tone
04-01-2012 8:31 PM
Who is your phone provider; Plusnet or BT.
If BT, unplug your router and go the the following web site and do a line test: https://www.bt.com/consumerFaultTracking/public/faults/tracking.do
If plusnet, ring the helpdesk
Message 2 of 7
(492 Views)
Re: No dial tone
05-01-2012 2:21 PM
Hi laurahoward,
I would firstly try a different handset in the test socket, to make sure your current handset/filter isn't causing the issue.
Jojo
Jojo
Message 3 of 7
(492 Views)
Re: No dial tone
05-01-2012 9:52 PM
Hi, I have now tried another phone and that won't work either!
Message 4 of 7
(492 Views)
Re: No dial tone
05-01-2012 11:37 PM
Then do what I suggested earlier.
Message 5 of 7
(492 Views)
Re: No dial tone
06-01-2012 11:08 AM
HI laurahoward,
Either raise a fault or call our support centre so we can get that sorted for you.
Jojo
Jojo
Message 6 of 7
(492 Views)
Re: No dial tone
09-01-2012 9:39 PM
Broadband working but no dial tone is usually because ONE wire in the cable pair has broken somewhere.
Might be in the house or it might be externally somewhere back to the exchange
If the test socket behind the NTE5 faceplate also doesn't give a dial tone then it is external and a matter for your phone supplier.
If the test socket does give a dial tone then it's your house wiring and your problem to sort.
The ringing sound people hear in their phone earpiece when they ring in is generated by the exchange not by your phone. You could disconnect every phone, broadband etc in your house on a known fully functional line and then ring in - and you would indeed hear the ringing tone in your earpiece.
Message 7 of 7
(492 Views)
