No dial tone.
- Home Phone
- No dial tone.
No dial tone.
25-10-2018 9:30 PM
Re: No dial tone.
26-10-2018 10:08 AM
Sorry to hear you're having problems with your telephone sockets.
Our tests aren't showing any issues and if your handset works in the test socket, but not your extension sockets that may indicate the issue lies with the extension wiring between the sockets.
Unfortunately we can't arrange an engineer to investigate this as our suppliers are only responsible for the line coming into the test socket, so I'd recommend finding a third party telephone engineer.
Alternatively if you can I'd leave your router and phone handset plugged into the test socket as that's always going to be the best place for the service, though I appreciate that's not always possible.
Apologies for any inconvenience this causes.
