No dial tone
- Home Phone
- Re: No dial tone
No dial tone
27-07-2014 8:56 AM
Hi
I recently got my line installed, fibre broadband is connected albeit at 7Mbs, but I'm working on that !!
However, when I pick up the phone I get no dial tone, just 3 beeps and a message on the phone display that says Busy. Although very occasionally I do get an actual dial tone.
I have dialled 1571 to check for messages but the same thing happens.
I guess it may be the phone itself, but I wanted to double check before I go out and buy a fresh one.
Matthew
Matthew
Message 1 of 3
(755 Views)
2 REPLIES 2
Re: No dial tone
27-07-2014 9:51 AM
If you've got a mobile give them a call on the 03 number so it doesn't cost a fortune, they should be able to run some checks for you. I'd have thought it sounds like a line fault more than a hardware fault. Have you tried ringing yourself?
Message 2 of 3
(359 Views)
Re: No dial tone
27-07-2014 10:24 AM
Notwithstanding, it's no bad thing to have a simple corded phone that does not need a power supply that you can use to make and receive land-line calls in the event of a power cut - even if you don't use it otherwise. You should be able to find one for about £10.
Message 3 of 3
(359 Views)
