No dial tone on land line but broadband still working - how to log a fault?
watercleaves
I can't phone for help because I have no dial tone.
I can't send the text for help because I don't have a mobile signal. ("Text PHONE to 07800008121")
There's nowhere on Plusnet's web site to report a fault on a land line.
What can I do?
Tags (1)
5 REPLIES 5
Legend
Fixes: 290
Re: No dial tone on land line but broadband still working - how to log a fault?
watercleaves
Thanks, I was able to open a case via the broadband fault report process!!
They've advised me it may take THREE DAYS to resolve the problem!
Legend
Fixes: 290
Glad that worked. The three days is due to the way the system works - PN report it to OpenReach, and they have a two day window due to the Service Level Agreement.
When you are advised it is fixed, I suggest you check your broadband connection is performing as you would expect, as phone faults can also impact that side of the circuit.
Fixes: 175
That is BT Openreach's target response time for RESIDENTAIL grade services ... which are not intended for to be used for time critical commercial purposes ... including WFH.
corringham
Seasoned Champion
Fixes: 19
Or calling an ambulance?
