No dial tone, incoming calls don't ring
- Home Phone
- No dial tone, incoming calls don't ring
20-01-2015 3:27 PM
Hi all my line has developed a strange fault I have no dial tone and when you call it the phone doesn't ring but phone shows incoming caller id and if you pick it up you still hear faintly the phone ringing but caller ends up going to answer phone. I created a support request last night at 21:00 but have had no response form plus net so far please advise
Peter
Peter
Message 1 of 7
(1,086 Views)
6 REPLIES 6
Re: No dial tone, incoming calls don't ring
20-01-2015 3:29 PM
It looks like someone has just replied before I had chance to!
Message 2 of 7
(612 Views)
20-01-2015 3:36 PM
Thanks Chris just got the email can you translate for me please
Fault Type:NDT Test Results:Fail - Fault located between DP and customer apparatus (no appointment required) / FAULT - Dis One Leg In Network What does this mesn
Message 3 of 7
(612 Views)
20-01-2015 3:39 PM
Putting it crudely
one of the wires - there are two - has broken or disconnected between you and the exchange
Message 4 of 7
(612 Views)
20-01-2015 3:40 PM
The fault type we tested for was NDT (No Dial Tone). The test results have detected a fault on the network, external to your house so we've been advised that it should be able to be fixed without an engineer needing to visit you.
Message 5 of 7
(612 Views)
20-01-2015 5:28 PM
Sorry to keep asking questions but would this also be the reason for a drop on speed on my adsl(possibly fault introduced noise) or is it just down to me troubleshooting as the router was over the weekend connected at around 13mb and now it's connected at 5mb. It's just I need to know whether I need to log another fault
Message 6 of 7
(612 Views)
20-01-2015 5:30 PM
At the moment there isn't a need to open a fault on the broadband, we can't actually report a fault on the broadband when there is already an open fault report on the phone, so we need to allow that to be fixed first.
It's very likely that your broadband issue will be sorted when the phone fault is fixed, post up on here if not and we'll take a look
Message 7 of 7
(612 Views)
- Home Phone
