No dial tone during a power cut
Anglo
Many moons ago, when I worked for Post Office Telephones, DC power was supplied down the wires so that a standard wired phone could work even if you had a power cut.  I have also seen helpful hints that say you should have a standard phone handy as any DECT phones will be useless in a power cut.
So last Friday when the power was off for near enough 12 hours I dug out an old phone and plugged it in but there was no dial tone.  Now the power is back on it works ok.  I wonder if the wiring for VDSL (fibre broadband) effects this?
My primary concern is for a number of aged Veterans in our British Legion Branch who have emergency call buttons and I worry that they may be isolated during a power cut.
4 REPLIES 4
mpmc
Re: No dial tone during a power cut
I'm sure all cabinets have backup power, so your line should've worked! Hopefully plus.net will be able to ask Openreach to see what's going on. Smiley
198kHz
Fixes: 41
Welcome to the forum.  Smiley
Quite a few moons since I left too, but what you say still holds.
VDSL shouldn't come into it, as you still have a continuous copper pair to the exchange for telephony. All exchanges, even the small rural ones, now have battery backup and a diesel generator. If the exchange was out of service for any length of time one would have thought it would have been reported in the local media.
All of which means that your lack of dial tone is somewhat mysterious. Did you perchance try the master test socket behind the faceplate?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Alex
Fixes: 13
I can't remember where I read it, but I've seen it twice where I am sure the cabs do. I believe they have a battery backup, which is only short term.
I am not sure how long a phone line will last without cabinet power though - 12 hours seems long.
Could have been running on battery within that time.
Mustrum
Fixes: 77
@Alex look at the response above.
The VDSL cabinet is battery is for the VDSL signal, not dial tone which comes from the exchange.
