No customer support
surfingblue
No customer support
I have a problem with noise on my landline ( I have tried all the suggested fixes, including sourcing a corded phone to plug straight into the master socket) we also have severe dropping out of the broadband and very flaky wifi, I have tried to ring customer support 08004320200 to report the fault, but after following the prompts, there is a message about online support via this community and the app and the the line goes dead, I have tried this for both tech support and customer services with the same result, perhaps I should say I'm a potential new customer, I'm sure someone would answer then! Any suggestions on how to report the fault
2 REPLIES 2
Legend
Fixes: 246
Re: No customer support
Welcome to the forums @surfingblue Follow the troubleshooting info on this link: https://www.plus.net/help/phone/
Sorry, you say you have followed all the suggestions - did you complete the 'phone troubleshooter' - if you did, this will have automatically have generated a ticket on the system, and PN will get back to you (on the ticket) as soon as possible.
Fixes: 1,596
Welcome to our community forums @surfingblue and apologies for the delayed staff response. I'm sorry for the issues with your service. I can see you've got through to us on the phone and an engineer has been out fixing a fault on your line.
I've tested your line today and the tests are all passing with no issues found. Let us know if you have any further issues.
