No Dialtone/Unstable Broadband.....but only when it rains!
- Home Phone
- Re: No Dialtone/Unstable Broadband.....but only wh...
29-04-2014 7:50 AM
When it rains or shortly after, I get a very loud crackle when making calls, usually followed by a loss of dialtone.
Now I'm loosing my broadband connection as well!
I've done all the checks, i.e:
Disconnected everything except a known working corded phone into the test socket with - still no dial tone.
What makes things even more frustrating is I live in an area with no mobile coverage so I rely on a landline!!!!!
Re: No Dialtone/Unstable Broadband.....but only when it rains!
29-04-2014 10:25 AM
Welcome to the Forums and I'm sorry you're experiencing issues with your phone and broadband service!
I've just a look into this and ran another line test which failed as our suppliers picked up on an external line fault. They expect the fault is located between the Distribution Point and your property. This means that an engineer should not be required to visit the property, however, they'll be carrying out external work. The estimated repair time for this is scheduled for 01/05/14 23:59:59. The fault may be resolved sooner, however, our Faults team will check back on this on 02/05/2014 after the ERT.
Hopefully this will be resolved for you soon and we're very sorry for any inconvenience caused by this.
29-04-2014 7:51 PM
Engineer arrived at 3pm, fault appears to be fixed!
Thanks Plusnet!
30-04-2014 11:55 AM
I've cleared the fault order with our suppliers and escalated the ticket back to you stating that it's now been resolved. If the problem comes back within the next 14 days please reply back to the ticket and this will go straight back to our Faults team, however, if the issue remains resolved then the ticket will automatically close after 14 days.
30-04-2014 4:17 PM
Might this user now benefit from a SNRM reset if they are on ADSL... or has the line picked up in an ideal state again?
30-04-2014 5:05 PM
- Home Phone
