No Dial Tone
absolutepleb
No Dial Tone
Our and line currently has no dial tone since the engineer came to upgrade to fibre. We bought another wired phone to test the line and it's the same. Tried the phone line sockets in both the porch and living room to no avail. Any suggestions?
5 REPLIES 5
MatthewWheeler
Fixes: 464
Re: No Dial Tone
Just running a few tests for you.
[EDIT]
Our tests are showing you have a loop fault which can sometimes be a internal issue.
You've mentioned you have two sockets where you have your phone's connected.
Which one is the master socket (the one the engineer worked on) and do you still have any microfilters in place?
 Matthew Wheeler
absolutepleb
Re: No Dial Tone
The sockets are in two different rooms. As far as I know the engineer fitted it on the secondary socket because there is no room for a phone/router in the porch (where the master socket is), he said said it wouldn't be a problem so I guess he switched something around. We aren't using any micro filters.
Gel
Aspiring Champion
Fixes: 28
Re: No Dial Tone
Would have thought any competent OR engineer would check for dial tone at the premises afore he leaves, having done
some engineering tasks.
absolutepleb
Re: No Dial Tone
I was asked to check the internet after he was done, which was fine.
Fixes: 356
Re: No Dial Tone
Unfortunately most installs are done by Contractors!
Unless a new filtered faceplate was fitted then you still need to use microfilters. Or it could be that whatever was done to the wiring isn't quite correct. Either way, try using a filter to connect the phone.
