No Dial Tone
- Home Phone
- Re: No Dial Tone
No Dial Tone
09-03-2016 11:45 AM
Our and line currently has no dial tone since the engineer came to upgrade to fibre. We bought another wired phone to test the line and it's the same. Tried the phone line sockets in both the porch and living room to no avail. Any suggestions?
Message 1 of 6
(1,442 Views)
5 REPLIES 5
Re: No Dial Tone
09-03-2016 11:47 AM
Just running a few tests for you.
[EDIT]
Our tests are showing you have a loop fault which can sometimes be a internal issue.
You've mentioned you have two sockets where you have your phone's connected.
Which one is the master socket (the one the engineer worked on) and do you still have any microfilters in place?
[EDIT]
Message 2 of 6
(552 Views)
Re: No Dial Tone
10-03-2016 9:46 AM
The sockets are in two different rooms. As far as I know the engineer fitted it on the secondary socket because there is no room for a phone/router in the porch (where the master socket is), he said said it wouldn't be a problem so I guess he switched something around. We aren't using any micro filters.
Message 3 of 6
(552 Views)
Re: No Dial Tone
10-03-2016 11:48 AM
Would have thought any competent OR engineer would check for dial tone at the premises afore he leaves, having done
some engineering tasks.
Message 4 of 6
(552 Views)
Re: No Dial Tone
11-03-2016 8:49 AM
I was asked to check the internet after he was done, which was fine.
Message 5 of 6
(552 Views)
Re: No Dial Tone
11-03-2016 9:09 AM
Quote Would have thought any competent OR engineer
Unfortunately most installs are done by Contractors!
Unless a new filtered faceplate was fitted then you still need to use microfilters. Or it could be that whatever was done to the wiring isn't quite correct. Either way, try using a filter to connect the phone.
Quote We aren't using any micro filters
Message 6 of 6
(552 Views)
