New line
- Home Phone
- Re: New line
New line
10-09-2017 9:46 PM
Re: New line
10-09-2017 9:53 PM
This means that the previous provider or Openreach have not left the line in a stopped state but rather disconnected this at a point beyond your property.
This means an engineer call-out is required of which we do ask for part payment towards this as part of the install, the engineer will not always need access to your home but someone will need to go out and do work somewhere on the line.
There is a chance the stopped line could pop back up as this can happen with Openreach records but you'd be best speaking to us to check that as it can change day to day.
Re: New line
10-09-2017 10:00 PM
Re: New line
10-09-2017 10:05 PM
Could you PM me the address of the property and I'll run some checks from here and get back to you, if they can see the line we should be able to also
Re: New line
10-09-2017 10:19 PM
Thank you for that message, I can see what's happening here.
We can indeed see the line however it's a line that's been stopped whilst connected to an LLU providers equipment meaning an Openreach engineer will need to disconnect the line from this and connect the line to the BT based equipment we connect through, as this does incur an engineering charge to ourselves when we place the order with Openreach we do pass a portion of this charge on at signup.
I would suggest giving our sales team a call however as they may be able to waive this fee dependant on contract length etc, I cannot confirm this for sure however there's no harm in a quick check in my opinion.
If you'd like to know more about this or have any other questions please do let me know
Re: New line
10-09-2017 10:24 PM
Re: New line
11-09-2017 4:52 PM
