New line installed
- Home Phone
- New line installed
New line installed
29-11-2013 3:13 PM
I ordered fibre on Monday, a BT engineer came round today and installed a new line and its active now, he just installed the standard faceplate and didn't bring a fibre modem, my appointment date says 18th December, was he just to install the line and another engineer will come on the 18th to fit a new faceplate and bring the modem? because it says 'Once your phone service has been installed, your broadband will be activated.'
Re: New line installed
29-11-2013 3:53 PM
29-11-2013 4:04 PM
29-11-2013 8:15 PM
ok its on plusnet now because im getting Sorry, you cannot call that number from this line on 150
30-11-2013 12:53 AM
If you go to the Phone Calls control panel and click the view button you should see an account summary panel showing your credit limit and the remaining amount. Other parts of the page and the tabs give additional information about your service.
30-11-2013 1:04 AM
Our records indicate that your telephone number may already be in use for Home Phone. This is a possible inconsistency with our records. If you wish to add Home Phone to your service please raise a question to our support centre and we will be happy to progress this for you.
30-11-2013 1:43 AM
If I click on the Phone Calls link in the Member Centre (highlighted in the attached image) I get what the image shows.
02-12-2013 5:07 PM
04-12-2013 4:20 AM
Edit: OK its getting sorted now, my number is now excepted in the checker but its showing this: http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput?TelNo=01494473709 it wont effect my Fibre order will it? this is another line in the building http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput?TelNo=01494440603 same cabinet.
04-12-2013 5:40 PM
05-12-2013 7:19 AM
