New line installation or Starting stopped line?
- Home Phone
- Re: New line installation or Starting stopped line...
16-11-2011 12:16 PM
There are a couple of things I can't understand. I know previous tenants and they had their broadband and phone through SKY. They cancelled their phone/broadband with SKY shortly before moving out. The property is a modern building with phone sockets etc. all installed properly and phone line/broadband was working fine right up until previous tenants cancelled just before moving out. Now why do I have to get a new phone line installed? when clearly the phone line was working fine just days before I placed my order. Surely it is simply a case of starting the stopped line? See Plusnets phone line FAQs below:
9. I don't have a telephone line, how long will it take to get one and how much will it cost?
To find out, please call our Sales Team.
Type of installation ------------------ How long will it take?
Installing a brand new line --------------- Depends on engineer appointment times
Starting a stopped phone line ----------- Within 2-4 working days
So it seems starting a stopped line is far far quicker than installing a new line, why wasn't I given this option?
Upon sign-up I was told next available date for installation was 18/11/2011 then on 4/11/2011 I got a text/email saying the date would be 22/11/2011 4 days further back still Now it is going to be about the 27th before I have broadband up and running, and I can't move into the new place until broadband is set-up as I require access for my business. So I've lost the best part of 1 months rent really.
The other thing is I understand that I should be available at my property on the installation date as the engineer may need access to my property. This is very difficult for me as it means taking time off work. I know there are perfectly functioning telephone sockets at the property (the modern 2 socket ADSL ones) & broadband and telephone line was working fine until it was stopped by previous tentants, so is there any reason why the engineer would actually need access?
£49.99 seems a steep price to pay to start a stopped line and 22 days also seems like a ridiculously long time to start a stopped line
Re: New line installation or Starting stopped line?
16-11-2011 12:35 PM
it very much sounds like a start of a stopped line couple be applicable. However it does depend on if the previous service has been ceased as opposed to stopped and that can often be the case with Sky services.
However I will look into this with a member of our provisioning team and will get back to you with an update ASAP.
16-11-2011 12:36 PM
16-11-2011 1:35 PM
I hope that clarifies things at least a bit for you, let me know if you have any further questions.
16-11-2011 2:54 PM
Quote from: hpares The other thing is I understand that I should be available at my property on the installation date as the engineer may need access to my property. This is very difficult for me as it means taking time off work. I know there are perfectly functioning telephone sockets at the property (the modern 2 socket ADSL ones) & broadband and telephone line was working fine until it was stopped by previous tentants, so is there any reason why the engineer would actually need access?
Any good engineer would presumably like to test that the line was working
16-11-2011 6:45 PM
Just out of curiosity what is the difference between a stopped and ceased line? and why would they choose to cease a line rather than stop it?
Also is it very likely the engineer will need access... or just probable? I am currently over 1.5hrs drive from the property in question so its not exactly easy for me just to pop along for a few hours.
16-11-2011 9:19 PM
The difference between a stopped and a ceased line is that when a line has been on the BT network and is disconnected it is just stopped. If this is started again it is done by a robot and is free of charge. Once a line has been stopped for a while it will then be disconnected (ceased) I imagine to make way for other lines. In the latter case that is when the engineer is needed, or when there has never been a line there.
If there is a BT socket there, it has been known that an engineer is not always needed, but if the line doesn't work, for some reason, when connected remotely then the engineer would need access to finish the job. Also, even if the line seems ok from the outside the engineer will often come to the premises to make sure is all working correctly both ways. In your case, it will definitely need an engineer to be booked, and you can't really take the chance that it will be ok, because if it isn't you'll have to pay the £49.99 again because of a missed appointment.
Jojo
23-11-2011 11:20 AM
BT engineers came yesterday (there was 2 of them together). They called at the property first, plugged in a little box thing into the phone socket then said: "Oh your line is already working... there is nothing we need to do" and that was that.
So I'm a little confused as to what went on, to me it looks like the phone line was never ceased, and actually seems like the engineers weren't even needed after all? So I took a day off work and drove 1.5hrs to get to the property and in reality it seems like it was completely pointless. Not to mention a £49.99 installation charge when the engineers didn't actually do anything. Oh and the icing on the cake is Plusnet are trying to charge me twice for the installtion fee (see topic here: http://community.plus.net/forum/index.php/topic,100236.0.html for full details).
I'm not exactly a happy bunny!
23-11-2011 11:47 AM
I'm sorry for any confusion here. I'll need to gain what info I can with regards to your order but I will make sure the second direct debit for the install fee gets stopped. I'll get back to you with regards to the first fee that was charged.
Adam.
23-11-2011 11:57 AM
23-11-2011 12:22 PM
With regards to the original install fee I can't see anything to support this being a start of a stopped line rather than an install. However in light of the doubt surrounding this and the duplicate fee that we should refund this too. That should be back in your account within the next 10 working days.
23-11-2011 12:28 PM
Quote from: hpares So I'm a little confused as to what went on, to me it looks like the phone line was never ceased, and actually seems like the engineers weren't even needed after all? So I took a day off work and drove 1.5hrs to get to the property and in reality it seems like it was completely pointless. Not to mention a £49.99 installation charge when the engineers didn't actually do anything.
When a line is ceased the connections in the exchange are removed and the cabling in the street become free to use. When the job was raised to connect you the connections in the exchange probably went to a Frames Engineer to do and for the Engineers that visited you to check the street cabling as they may have been reused and the records are not always updated to reflect this.
23-11-2011 12:34 PM
I guess PlusNet's hands are tied though, if the BT database says its not a stopped line then its an install...
23-11-2011 12:38 PM
Edit: It's normal for the work in the exchange to be done a day or 2 in advance before passing over to the CSE's
23-11-2011 1:58 PM
Quote from: _Adam_Walker_ I'm sorry to say that I'm not able to stop the second direct debit going through I'm afraid. I will make sure you get refunded as soon as it clears (this may take around 7-10 days).
That's a nuisance that the second debit cannot be stopped... but waiving the original fee certainly makes me happier about the whole affair. Thank you for your help Adam, you have been very informative and helpful
- Home Phone
