New customer - unable to dial out!!!
- Home Phone
- Re: New customer - unable to dial out!!!
20-11-2011 11:33 PM
I moved into a new house (renting) yesterday - Saturday 20th November.
The phone line was activated on Friday 11th November in order for the Fibre Broadband to be installed this coming Tuesday.
As the previous tenants were still living in the property until last Wednesday I asked for a block to be put on the line so that they could not Dial out.
Having now moved in, I have a dial-tone however when dialling a number it just cuts the call and is unable to make a connection.
I have tried the main phone socket and also the master socket tna.
There is no other service on this line and am unsure what would be causing this.
I have also dialed 1280 as a prefix before dialling a number however this makes no difference.
Having spoken with Plus.net CS today the lady I spoke with advised she could send out a BT Engineer to my property on Tuesday afternoon to check the line and equipment.
However she advised if any faults were found with the equipment in my property I would be charged.
Would I need to pay the charge or do you think my landlord would need to as the fixtures and fittings do not belong to myself
Please could you run some tests and have a look into this for me.
This shouldn't affect the Fibre installation on Tuesday should it? As they 're replacing the BT box in the house for the Fibre hardware would it be an idea to pospone the other BT engineer from coming round to see whether the change in equipment rectifies the landline fault?
Looking forward to a reply.
Message 1 of 3
(3,647 Views)
2 REPLIES 2
21-11-2011 7:15 AM
Quote The phone line was activated on Friday 11th November in order for the Fibre Broadband to be installed this coming Tuesday.
er um, has the block been removed? surely thats up to you
Message 2 of 3
(413 Views)
21-11-2011 11:42 AM
Quote from: active8 As the previous tenants were still living in the property until last Wednesday I asked for a block to be put on the line so that they could not Dial out.
you will need to call to have this removed.
Quote from: active8 This shouldn't affect the Fibre installation on Tuesday should it?
No, your installation will not be affected.
Jojo
Message 3 of 3
(413 Views)
- Home Phone
