New build - new line but no broadband?
- Home Phone
- New build - new line but no broadband?
29-02-2012 11:23 AM
A friend is about to move into a newly built property which so far has no phone line installed. She has been told by BT that the property can have a phone line installed but cannot have broadband!!! The village where the house is does have broadband.
I have Googled this issue and it seems most likely that this is simply an administrative problem and that the system is not set up to simultaneously provide phone and broadband to new-builds. One thread referred to something called a LORN (Linked Order Reference Number) which can be used to tie two orders together where no phone number exists.
Has anyone had experience of this situation and are Plusnet a good bet under these circumstances?
Tony
Tony
Message 1 of 6
(3,197 Views)
5 REPLIES 5
Re: New build - new line but no broadband?
29-02-2012 11:43 AM
It's not because the area is supplied by TPON
Quote Some telephone lines are provided partly over a fibre optic connection which stops you being able to get a broadband connection. This is known as TPON.
Message 2 of 6
(515 Views)
29-02-2012 11:46 AM
Drop me a DM with your friends new address details and I'll run some checks for you.
LORN, is usually used in relation to simultaneous orders where the line and broadband are activated simultaneously, that isn't always possible but I should be able to say if it's a possibility for your friend when I've seen the account.
Message 3 of 6
(515 Views)
29-02-2012 4:26 PM
Message 4 of 6
(515 Views)
29-02-2012 11:17 PM
Thanks for your help.
Message 5 of 6
(515 Views)
01-03-2012 12:42 PM
Message 6 of 6
(515 Views)
- Home Phone
