New bill format - duration of calls formatting
reproman
I have noticed a bug in the new bill format on the website, it is how the times are used for the duration of calls...
On the bill itself, it is HH:MM:SS
In the 'View billed calls' area it shows as HH:MM:SS.CS (CS = centiseconds!?)
When exporting the billed calls, the formatting goes back to HH:MM:SS but this is where it goes wrong, the CSV download cannot interpret this non-standard notation of centiseconds and simply spits out nothing.
Is a unit of centiseconds really needed, or indeed any reason to break-down time further than a second?
Please remove the 'centiseconds' unit so that exports can be done without copy-paste-alter-repeat multiple times?
Thank you.
Tags (1)
2 REPLIES 2
Satss
Fixes: 37
Re: New bill format - duration of calls formatting
Hi @reproman
Thank you for bringing this to our attention. I will feed this back to our billing team so that they can look into this.
peter6000
I've just tried exporting a CSV of calls and the column title is now:
   "Duration hr:min:sec"
but there's no data for that column.
Also, a couple of other related questions:
1. What does the "late rated" column show?
2. It's not really a problem to me, but should a CSV file really contain subtotals and totals?
Thanks,
Peter.
