Need advice on landline
EDD1
I have a BT Socket but internet fibre with plusnet .I need to buy a BT phone can i plug into the socket. Without effecting the router.
5 REPLIES 5
Legend
Fixes: 293
Re: Need advice on landline
@EDD1 The simple answer is yes. Which Master socket do you have - one with a single socket , or one of the newer dual socket ones?
EDD1
Dual socket
Legend
Fixes: 293
In which case, just plug the phone into the 'phone' socket and you're good to go.
@EDD1
Before you buy a new BT phone, are you aware that the UK phone system is being switched off at the end of 2025 ?
BT Publish UK Regional Rollout Schedule for Digital Voice
Rather than spending money on a soon to become obsolete phone to plug into the BT socket (for maybe 18 months),  you might want to consider future-proofing your purchase with the replacement technology - a "VoIP" telephone, which plugs into your broadband router, and your voice calls are made over the internet, but otherwise the handset works the same as now.
HPsauce
Seasoned Pro
Fixes: 4
@EDD1 you say you have "fibre". Presumably you mean FTTC, i.e. Fibre To The Cabinet, with a  copper cable into your house.
As noted above there's a transition to Digital voice planned, do you even have a phone service on the line, it's possible you don't. PlusNet are phasing out phone services anyway.
Try ands borrow a phone from a friend/neighbour and plug it in. If you get a dial tone call 17070 which is a test number that will also conform the phone number assigned.
