My landline is'nt ringing out but I can make calls?
linda3940
Just browsing
Hi
I have a dialing tone I have rang my landline from my mobile and I can answer it but it does'nt ring out can anyone help please....I have also purchased a new digital cordless phone and its the same problem ?
3 REPLIES 3
SeaDog9
Browser
Re: My landline is'nt ringing out but I can make calls?
Linda,
Do mean when some one rings you the phone does not ring but you can make calls out?
If that is the case it is a fault in the exchange. I know this as our son is an Openreach engineer. But when you contact  Plusnet they will test your line & it will come back "No fault found" this is because the fault is not on the line
You really have to emphasise this to them. We had the same problem & had to contact them through facebook in the end. Good luck
Strat
Fixes: 565
Moderator's note by Dick (Strat) Duplicate post removed.
Windows 10 Firefox 107.0 (64-bit)
Chris
Legend
Fixes: 169
Hi Linda,
Is this sorted for you now?
