My caller display has stopped working, any advice please?
jelv
Fixes: 10
Re: My caller display has stopped working, any advice please?
Have you tried disabling and enabling it yourself?
Dial #234# to disable it.
Dial *#234# to check that's worked.
Dial *234# to enable it.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
kmw350
Quote from: spoon
Thanks for the suggestion, but it did not work.
I confirmed I had disabled it, then reenabled it.
As before, I get the message 'caller id will be displayed', and yet they are not.
MatthewWheeler
Fixes: 479
I'm hoping to have a poisitive update on this tomorrow.
Leave it with me.
 Matthew Wheeler
kmw350
Waiting with hope and anticipation since your last post Wink
jimbo121
I am watching this with baited breath as I have exactly the same problem, BT engineers found a fault but this has not fixed the ID problem, nearly sent my new phones back as faulty but tried them on somebody else's line and the caller ID worked.
kmw350
Hey Matthew, any news on the possible positive update you were expecting a few days ago ?
Cheers  Sad
MatthewWheeler
Fixes: 479
Unfortunately it's taking longer then expected.
Caller Display faults can take a while to get sorted but we'll get it fixed as soon as we can.
 Matthew Wheeler
kmw350
many thanks for the update, good to know there's still hope  Smiley
kmw350
Two weeks on Matthew, can you confirm this is still being investigated please? I still have no caller ID being displayed. Sad
MatthewWheeler
Fixes: 479
Still working on it I'm afraid.
Caller display issues can be complicated.
 Matthew Wheeler
jimbo121
How complicated can they be, into my second month now without caller ID,
kmw350
Wondering the same Jimbo Sad
jimbo121
Hi Kmw, after been told several times my fault had been fixed and me replying no it isn't I've just had the Openreach guy in my home he asked what the fault was I told him 'caller ID' not working as he had not done one of these before he had no idea what it even was, he rang several colleagues but made nothing out with them,  said he would ask somebody else and then left, the one thing I have learnt today is NOT to hold my breath waiting for this shambles to get sorted, I hope you fare better than me, Regards jimbo
jockwav
Shocking.! Shocked Huh
https://www.flickr.com/photos/james_bingham/
kmw350
Well, thanks for the comments, no I'm not holding my breath, but I am not giving up on it either. It worked fine for several years and now it doesn't and I would like the cause to be found and fixed.
I was sick of all the unsolicited calls and I do not want them to start again. Sad
