My caller display has stopped working, any advice please?
chalbury
Re: My caller display has stopped working, any advice please?
Switch off/switch on seems to be becoming the standard method of fixing this problem instead of research into the root cause.
kmw350
Quote from: Chris
I'm going to simply try removing/readding caller ID. The fault I raised has closed as no issue was found, so before going down the route of sending engineers to investigate this seems like a good step. I'll update you when I've re-added it back to your line.
That's understood, many thanks for the update Chris. I'll wait to hear further.
Quote from: chalbury
Chalbury,
will you kindly STOP posting your unhelpful comments in this thread. Chris is helping me with a problem and I appreciate it. If you have a gripe then please create your own thread or contact PlusNet directly. My problem is not your problem. Thank you.
Strat
Fixes: 565
Just to make that a little more official, Chalbury please stop spamming kmw350's thread with unnecessary comments.
It makes Plusnet Support's work more difficult.
chalbury
I thought that I was being helpful since switching off then switching on seems to cure the problem.
MatthewWheeler
Fixes: 479
@kmw350
I've placed the order to re-add your caller display.
It should be up and running in the next hour or so.
 Matthew Wheeler
kmw350
Thank you Matthew, still no change at this end yet though. I have added some information to my support question that might help the investigation.
Regards
KMW
dick:quote
kmw350
Quote from: Chris
Any news on this Chris? The feature was removed and re-added but it has not fixed the problem.
*#234# still tells me 'caller IDs will be displayed'; I have a new phone; I've tried form the master socket, but I am still not seeing any phone numbers displayed.
regards
Keith
Chris
Legend
Fixes: 169
Really sorry to hear that. We're probably going to need to go through looking at a fault, although I'd like Matthew to take a look first to see his thoughts. I'm off all week next week so will ask someone else on the team to pick this up for you.
adamwalker
Fixes: 221
Everything should be in order now kmw350
Give me a shout if there's any issues.
 Adam Walker
kmw350
Adam,
No, unfortunately there is no change at my end.
The situation has been the same since the power cut a couple of weeks ago when I first reported it.
If I dial *#234# it says 'caller id will be displayed', but they are not.
I have tried 3 different phones, including from the main socket.
thanks
Keith
dick:quote
MatthewWheeler
Fixes: 479
Let me look into this again.
[EDIT]
I've sent off a request for them to check the exchange. As soon as I have a update I'll let you know.
 Matthew Wheeler
kmw350
Thanks Matthew,  a BT engineer has just been to my house and could not find any fault on the line, I have updated the support ticket to that effect. He suggested the problem must be at the 'provider's end' so I hope there is something else you can look at.
Cheers
Keith
dick:quote
MatthewWheeler
Fixes: 479
The engineer not being able to fault has stumped me a little.
Let me have another look.
 Matthew Wheeler
kmw350
Quote from: Matthew
OK, also, I am getting more disconnects than usual. Several in the last few days, which I do not normally get, I don't know if that has anything to do with it, or just coincidence?
kmw350
The disconnects have settled down, seems back to normal,
BUT still no caller ID display, I hope something can be done to get this working again, please don't give up on it, I was SICK of all those &*%$ PPI calls and I do not want to have to answer them again.   Sad
