My caller display has stopped working, any advice please?
- Home Phone
- Re: My caller display has stopped working, any adv...
14-08-2015 10:20 AM
my caller display option has worked fine up to about a week ago.
There was a brief power cut in the local area, and since then, the display has disappeared.
Several neighbours had problems with their phones at the same time.
Is there any way to determine if there is a problem remaining at the exchange as a result of the power cut?
Any help appreciated,
Cheers:)
Re: My caller display has stopped working, any advice please?
14-08-2015 10:23 AM
14-08-2015 10:31 AM
thanks for the quick response,
Do you need any other details?
Keith
14-08-2015 10:35 AM
The first thing to do is check that the service is enabled on your line. You can do this by dialling *#234# . If there is an announcement to state that the service is disabled, please try enabling it by dialling *234# .
If this doesn't help with the problem, please try plugging the phone directly into the master BT socket in your premises, then unplug all other equipment from the line such as extra phones, broadband router and filters, fax machines etc and see if this makes a difference.
(The reason for this is that Caller Display comes down the line as a signal, and we need to check that nothing in your premises is interfering with this signal).
I've reported the fault in the meantime, but if you could check those steps that'd be great.
14-08-2015 10:38 AM
I am not aware of this being shown elsewhere
Would it be a good idea to add this and other similar tests to a sticky at the top of this board
14-08-2015 10:42 AM
14-08-2015 10:45 AM
Your Caller Display has been removed yesterday when you contacted us. Do you want it readding?
@Oldjim
Possibly, most of the information should be available at http://www.plus.net/support/phone/troubleshooting.shtml though.
14-08-2015 11:14 AM
I checked the *#234# and it confirms that caller ids should be displayed.
Same result at the main socket.
I have also tried a second phone and the problem is still there.
(Don't know if it was coincidence or due to your checks, but I have also just had numerous disconnects, hence my delay in replying. But it is connected and stable again now).
14-08-2015 3:38 PM
14-08-2015 3:50 PM
I'll keep my eye on the fault and update you on Monday when I'm back in the office.
14-08-2015 8:32 PM
14-08-2015 9:06 PM
Quote from: Chris @kmw350
Thank you Chris, in the meantime I am buying a new phone tomorrow (needed one anyway), which will ensure the power cut didn't damage my old one & break the caller ID in some way.
14-08-2015 9:10 PM
15-08-2015 11:26 AM
Chris,
Update - new phone bought, and the situation is the same - the *#234# message tells me that 'caller ID will be displayed' but when I get someone to call me, the caller ID is still not showing up.
Thanks again for looking into this, I hope your team can fix it,
Keith
18-08-2015 11:49 AM
- Home Phone
