My answerphone has stopped working
- Home Phone
- My answerphone has stopped working
12-06-2009 1:18 PM
Hi
Since moving from BT the answerphone my Panasonic cordless phone has stopped working. Internet fine, phone fine, answerphone emits modem like burblings when it picks up the line..
Is this a common issue?
Message 1 of 5
(1,715 Views)
4 REPLIES 4
Re: My answerphone has stopped working
12-06-2009 1:30 PM
Do you have the free Voicemail that Plusnet Home Phone offer activated?
Message 2 of 5
(451 Views)
12-06-2009 1:46 PM
Good question, it could be that the BT answerphone is kicking in before the Panasonic one.
Message 3 of 5
(451 Views)
15-06-2009 11:49 PM
Sorry to have posted a questionthen disappeared............been away
I have the value package and so don't get free voicemail so , no I don't have voicemail activated....The phone also does not ring correctly we just get the odd single ring it sounds normal when ringing in then the digital noise starts.................anybody still listening?
Message 4 of 5
(451 Views)
16-06-2009 7:46 AM
Is it just the broadband you've moved or broadband and phone?
Have you got the phone plugged into the phone socket of a microfilter and have you got a microfilter plugged in at every telephone socket where you have something connected (phone/router/Sky box etc.)
It sounds as though you may have the phone plugged into an unfiltered socket.
If everything is filtered, it's worth trying new filters (and a known working phone) to see if that's the problem.
It's unlikely that moving phone provider has caused the problem as the underlying service is the same (BT/Plusnet etc. all use the same equipment at the exchange it's just the billing that's different - the exception being LLU providers but that's not the case here).
Message 5 of 5
(451 Views)
- Home Phone
