Mobile Apps
- Home Phone
- Mobile Apps
Mobile Apps
23-05-2015 11:53 AM
Folks,
Just transferred to plusnet after 40+ years with BT so finding my way about.
Are there any phone apps that enable use of plusnet phone when away fom home?
Geffers
Geffers
Message 1 of 4
(1,424 Views)
3 REPLIES 3
Re: Mobile Apps
23-05-2015 12:44 PM
Hi there Geffers, and welcome to Plusnet!
Unfortunately there isn't an app for that, but if you need your calls to come through to you when you're not at home, we do offer the Call Divert feature for £2.50 per month. I hope that this helps!
Message 2 of 4
(448 Views)
Re: Mobile Apps
23-05-2015 1:26 PM
and if you are diverting to a mobile you will be charged for the call I believe
Message 3 of 4
(448 Views)
Re: Mobile Apps
23-05-2015 2:55 PM
It depends on which call package you have with us. Whilst call divert is on, you would be charged for incoming calls on the same basis as you are charged for outgoing ones on whichever call plan you're on.
So for example, if you're on Anytime with Mobile bolt-on and were diverting to a mobile, you'd only be charged for your diverted calls after the first 100 minutes had been used up (or if a call went over 60 minutes), it that makes sense
Message 4 of 4
(448 Views)
