Master socket
- Home Phone
- Master socket
Master socket
30-09-2013 11:56 AM
Hiya,
We're moving into our new build house shortly I noticed the master socket (at least it lines up perfectly with the grey openreach box on the external wall) looks like this:
Do BT install a fatter master socket when they install the line? Or do they use slimmer ones these days?
Message 1 of 5
(1,136 Views)
4 REPLIES 4
Re: Master socket
30-09-2013 12:06 PM
Does the external box look like the one below? If so that's the master and the photo you supplied is for a normal extension socket
Message 2 of 5
(455 Views)
Re: Master socket
30-09-2013 12:32 PM
Aha yes it is! So the master sockets are outside now? Odd. I was hoping to replace the standard plates with an adsl filter plate but I'm guessing that's not possible now.
Do these ones have a test socket inside still?
Thanks for the reply
Message 3 of 5
(455 Views)
Re: Master socket
30-09-2013 12:41 PM
There's some information about these at the bottom of this page: http://www.kitz.co.uk/adsl/btsockets.htm
Message 4 of 5
(455 Views)
Re: Master socket
30-09-2013 12:46 PM
Thanks for the info. So no user test socket booo. Will ask the guy installing the line to hopefully disconnect all extensions apart from the main one. We have wireless dect phones and rather lose the risk of adsl interference at the cost of the extensions.
Thanks again.
Thanks again.
Message 5 of 5
(455 Views)
