Lost Caller ID after transferring from BT
stevengcowley
Joined PlusNet four months ago but lost caller ID when we transferred. It was working OKpreviously when on BT.
I seen other people have the issue but no way to actually report the issue!
How do we get this resolved
6 REPLIES 6
Fixes: 558
Re: Lost Caller ID after transferring from BT
@stevengcowley Two options, you can either call Customer services and report the fault , or wait for one of the Plusnet help team to pick this up and assist.
willcutforth
Fixes: 113
I've made some adjustments for you @stevengcowley so it should work within the next hour but give it 24 hours and if it's not working please do let us know.
 Will Cutforth
stevengcowley
Thanks Will, Caller ID is now working
willcutforth
Fixes: 113
Awesome, glad to hear it. You know where we are if you need us.
 Will Cutforth
crystalamina
Hi, we have exactly the same problem. The ' control panel ' says that Caller Display is active, and I have tried the " *234# ", where I get the reply - This service is not available? Can you please advise what next please?
James30
Fixes: 32
@crystalamina - I recon I've sorted it. Sorry for the trouble, can you give it a go in 4 hours and let me know if it's still not working. Thanks
I've left a note on you account here @ https://www.plus.net/wizard/?p=view_question&id=236832646
James - Plusnet Sheffield
