Landline
- Home Phone
- Landline
Landline
12-09-2018 4:07 PM
Landline phone doesn’t seem to be getting any power through. It is a BT cordless with an answering machine.
Message 1 of 4
(517 Views)
3 REPLIES 3
Re: Landline
12-09-2018 5:41 PM
Do you mean no 'power' from the line - that is - no dial tone.
Or do you mean no mains power to the cordless base unit - that is - no lights or display.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 2 of 4
(498 Views)
Re: Landline
12-09-2018 5:51 PM
It seems like no mains power. I ve checked all the cables and plug and they all seem to be in correctly.
Message 3 of 4
(492 Views)
Re: Landline
12-09-2018 6:58 PM
OK. The prime suspect would be the power supply. Worth checking the fuse in the plug first though - with a meter, or swapping with another appliance. If the fuse is OK...
Do you have a multimeter, or know anyone who could test the DC output of the power supply?
Message 4 of 4
(482 Views)
