Landline voicemail
cgasltd
Landline voicemail
Please how can my voicemail feature be turned off? I never ordered it and am unable to deactivate it online at the remove features page.
I want to keep caller display & have my own answer phone.
Thanks to anyone that can help
3 REPLIES 3
EmilyD
Fixes: 117
Re: Landline voicemail
Hi @cgasltd,
Thank you for getting in touch, I'm sorry that it's not allowing you to deactivate the voicemail feature via the member centre. I've had a look into this and it was showing that the feature has been removed on our side, but was still active on our supplier's side. I've placed an order to fully remove the voicemail feature on your line from our supplier's side and this will complete within 72 hours.
 Emily D
cgasltd
That'll be great, Thank You.
cgasltd
Thank You Emily, all sorted.👍
