Landline telephone
chimiste
Landline telephone
Landline phone is not functioning for both icoming and outgoing calls.  The fault was reported by texting PHONE to 07800008121 at 10.16 am this morning.  I have had no message in response to my text.  Attempts to use the customer services number 08004320200 using my mobile failed since having pressed 1 as instructed I was the unable to remove this before typing my phone number.
Moderator's note by Mike (Mav): Post released from Spam Filter.
1 REPLY 1
markhawkin
Seasoned Pro
Fixes: 16
Re: Landline telephone
@chimiste
On the assumption that you have broadband, does that still work over the phone line?
If so, has it got slower?
I don't think the "1" in the call navigation will upset reporting the faulty phone number.
I haven't had to report a phone line fault for a few years but I think last time i did it via
https://faults.plus.net
which if I recall correctly, asked a few questions then logged the fauly.
