Landline shut down
oilcloth
Landline shut down
If i switch to Plusnet Broadband only and lose my phone line ...... can I get an adapter from Plusnet that will plug into my router to allow the phone to work via the Broadband network
4 REPLIES 4
Fixes: 117
Re: Landline shut down
@oilcloth
The quick answer is yes. However, you need to set up a VOIP account with someone and if you want to keep your number "port" it out within 30 days. Have a look at the FAQ for A&A page to get some answers on VOIP.
https://www.aa.net.uk/voice-and-mobile/voip-information/
Fixes: 479
@oilcloth
To clarify. You can get an adapter that will work with your Plusnet service, but NOT from Plusnet.
Fixes: 117
@Baldrick1
Sorry about that. In my rush to answer before shutting down for the evening I missed the question about it being PN supplied.
HPsauce
All Star
Fixes: 5
@oilcloth a further clarification. The "adapter" you need is a network device (usually called an ATA - Analogue Telephone Adapter) that connects to your router via a standard ethernet cable, so you need a spare ethernet port on the router for it.
Plusnet have nothing to do with such VOIP phone services, you need to obtain the necessary kit and set up a VOIP account yourself. Some companies can supply both the service and the equipment.
IMPORTANT if you think your router has a phone socket (covered up usually) - NO IT DOESN'T. That socket does not work with the PlusNet router, though the very similar BT routers have a similar socket and can use it ON BT BROADBAND services, which causes regular speculation and confusion.
