Landline not working
FIXED- Subscribe to RSS Feed
- Home Phone
- Landline not working
28-06-2021 10:39 PM - edited 28-06-2021 10:40 PM
Landline is not working, ie. there is no dial tone and I cannot make or receive any calls. It started in the last week and there have been no changes to my setup. I have followed the troubleshoot advice, and tested with several telephones, both corded and cordless. Tried to run several line tests via the Plusnet site, only to be told that the result was unclear.
I should add that my internet connection is working fine.
Any help would be appreciated.
Regards.
Fixed! Go to the fix.
Re: Landline not working
29-06-2021 6:53 AM
Welcome to the forums, @Maddog . If you have run the tests, have you checked that the system hasn't raised a ticket automatically - despite the 'unclear' response?
29-06-2021 12:11 PM
Hi @Maddog
Thanks for reaching out, we may be having an issue with our Troubleshooter at the moment, whereby definitive results aren't made clear, and a Ticket is not being raised on our end. We're keeping an eye on this and will have it raised should it continue.
In regards to your line, I've run a test this morning which has found a disconnection within the network, this has been raised to Openreach and we're hoping to have it addressed by 01/07/2021. Apologies for any inconvenience caused here.
I've raised a fault Ticket on you're account which you can both view and add comments to here
29-06-2021 2:02 PM
Many thanks for the quick replies. Hopefully this should solve the issue!
05-07-2021 3:48 PM
Everything is now working correctly. Many thanks for your help.
05-07-2021 3:58 PM
Thanks for the confirmation @Maddog
I'm glad to see your phone's now working.
Let us know if there are further issues or anything else you'd need help with.
