Landline not working
Hazelnut
How do I get my landline to my house telephone checked.  Have called customer services and after 20 minutes got a reply.  Had forgotten user name etc but only need landline checked?Huh
6 REPLIES 6
chenks76
All Star
Fixes: 12
Re: Landline not working
so after you got a reply what did you say to them? and what did they say to you ?
Hazelnut
They need my username and password.
As my mother is 78 and no computer or e-mail address I have now registered to try to get this fixed for her.  So when I said no username and password and not giving them bank details over the phone - nothing can be done to check the landline!  We tried alternative phone and plugging it in and nothing happened apart from same message 'check landline'.
chenks76
All Star
Fixes: 12
i assume you are not the account holder and you weren't able to pass the security questions so that they could check the account?
Hazelnut
Know everything as myself and my sister usually keep my mother right!
Strat
Fixes: 565
Moderator's note by Dick (Strat) Topic moved to what should be the correct board for clarity.
Fixes: 1,600
If you PM me your landline number I'll run a test for you
Thanks for your private message.
From what I can see an engineer investigated and rectified a line fault earlier this morning. Everything working now?
