Landline help
Aspiring Legend
Fixes: 135
Re: Landline help
@coopers If that loose socket is no longer used, I can't see why you can't chop it as close to the  main box as possible.
@MisterW  @198kHz  - Am I correct?
198kHz
Fixes: 36
Re: Landline help
If it was me I'd remove the faceplate and take the cable completely out.
If the OP is hesitant to do that, chopping it near the box will suffice. So long as it's a clean cut such that there's no chance of any wires touching.
If you want the best seat in the house, move the cat
FTTC 40/10   Billion 8800NL
BT technician (Retired)
Aspiring Legend
Fixes: 135
Re: Landline help
Good thinking @198kHz - never thought of just taking it completely out.
198kHz
Fixes: 36
Re: Landline help
Oops, I should have added -
De-power the router first - remove cable - power up.
Not necessary if it's just a chop.
coopers
Re: Landline help
Thank you all so much. You don't know how grateful I am to get this help.
Thank you all again.
198kHz
Fixes: 36
Re: Landline help
Cheers.
That's what the forum's all about - helping each other. Don't hesitate to shout up if you need anything in the future.
