Landline has no dial tone
misselectro
My landline has no dial tone and I am unable to speak to anyone directly so I am posting here. I am also having problems with my Unlimited Fibre broadband but I will post that in the other forum.
Is there any way of someone:
A) Checking my phoneline
B) Being able to tell me if this fault could be related to my broadband issue?
I have checked all the wires, I currently have a cordless handset but do not have a wired phone to check directly, and am unable to go out and get one. If anyone can advise it would be much appreciated, as I am supposed to be working from home and my job is supporting vulnerable adults. Thank you.
2 REPLIES 2
BrightonRock
Fixes: 7
Re: Landline has no dial tone
Welcome to the Forum @misselectro
The problems that you are seeing may well be linked. The usual advice is to try to get the phone sorted first. Try running through the advice on the Plusnet website https://www.plus.net/help/phone/
If the suggestions for local steps don't offer a solution you will end up running the online troubleshooting at https://www.plus.net/my-account/tools/phone-troubleshooter/
If there is a problem with the line, that should report it to Openreach/Plusnet and create a ticket on your Plusnet account (at Plus.net, not here on the Forum)
MatthewWheeler
Fixes: 456
Thanks for getting in touch @misselectro and apologies for the delayed response.
I'm sorry to hear that you're having issues with your phone line
I've tested your line and identified a fault at the local exchange
This has been raised for further investigation and we'll update you as soon as we know more
 Matthew Wheeler
