Landline Provision
bures
Landline Provision
I am currently with PN with a Broadband and phone package
I am going to change the fibre broadband to mobile broadband (2x speed) but I want to retain the landline
Can PN continue to provide this phone  and what is the rental cost ?
Tags (1)
4 REPLIES 4
Fixes: 386
Re: Landline Provision
In a word, @bures  - no. PN, like the majority of ISPs these days, only do combined broadband and phone packages. So far as I know, only BT (of the big players, do phone only - or they did last time I had cause to look, maybe 12 months ago.
bures
Thanks for being so quick
That confirms why I can see no mention on the PN website
Only really want if for incoming calls, so BT`s high rental out of the question
I will use my mobile number instead
Probably try and figure out how a VOIP works with a Mobile Router
Fixes: 250
Moving the number to VoIP is the right answer and VoIP will work over mobile internet much the same as everything else does over fixed line internet.  The important consideration is that the mobile internet needs to be always on.
bures
Thanks for the info on VOIP
Presumably I have to join someone like Sipgate
