Landline Open
Kay26
Landline Open
Landline open hearing busy signal and lots of noise.
9 REPLIES 9
Kay26
Broadband Unstable
Broadband intermittent, unreliable.
Legend
Fixes: 255
Re: Broadband Unstable
@Kay26 Welcome to the forums. This will be related to your landline phone problems on your other thread. You need to resolve those first, and you will probably find you internet problems resolve themselves.
Who do you pay your line rental to?
Strat
Fixes: 565
Moderator's note by Dick (Strat) Topics merged.
Kay26
Plus Net!  Broadband more stable but landline a mess!
Kay26
Re: Landline Open
Not fixed!!!
Moderator's note by Dick (Strat): All caps title/text edited as per Forum rules.
Legend
Fixes: 255
OK. In that case, I would run through the phone help topic on the 'Help and Support' tab at the top of the page - until you have resolved that, your broadband will never properly stabilise.
Kay26
Landline not fixed, mistake.
tinytaco
Fixes: 29
Hi there Smiley I can see our Tech guys found an external fault on your line, you can monitor the Fault and update it on your account here.
 Noor
EmilyD
Fixes: 117
Hi @Kay26,
Apologies for the delay in getting back to you on here and for any inconvenience that this fault is causing.
I can see that you have since discussed this with our technical support team and they have found an external fault when testing your line. This has been raised to our suppliers for further investigation and we are due an update by Monday the 15th of June.
 Emily D
