Landline Open
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Broadband Unstable
11-06-2020 1:15 PM
Landline open hearing busy signal and lots of noise.
Fixed! Go to the fix.
Broadband Unstable
11-06-2020 1:17 PM
Broadband intermittent, unreliable.
11-06-2020 2:18 PM
@Kay26 Welcome to the forums. This will be related to your landline phone problems on your other thread. You need to resolve those first, and you will probably find you internet problems resolve themselves.
Who do you pay your line rental to?
11-06-2020 2:32 PM
Moderator's note by Dick (Strat) Topics merged.
11-06-2020 2:49 PM
Plus Net! Broadband more stable but landline a mess!
Re: Landline Open
on 11-06-2020 2:51 PM - last edited on 11-06-2020 2:56 PM by Strat
Not fixed!!!
Moderator's note by Dick (Strat): All caps title/text edited as per Forum rules.
11-06-2020 2:53 PM
OK. In that case, I would run through the phone help topic on the 'Help and Support' tab at the top of the page - until you have resolved that, your broadband will never properly stabilise.
11-06-2020 2:54 PM
Landline not fixed, mistake.
12-06-2020 1:41 PM
Hi there I can see our Tech guys found an external fault on your line, you can monitor the Fault and update it on your account here.
12-06-2020 2:42 PM
Hi @Kay26,
Apologies for the delay in getting back to you on here and for any inconvenience that this fault is causing.
I can see that you have since discussed this with our technical support team and they have found an external fault when testing your line. This has been raised to our suppliers for further investigation and we are due an update by Monday the 15th of June.
