Just curious - what determines whether international call is charged.
longedge
Fixes: 4
I made a call to the Canaries the other day and I was surprised to see it got charged. No complaints as it's quite clear in the list of countries that calls to the the Canaries are not included in the 'free' minutes but it made me wonder what it is that triggers charging. Until now I always thought it was the country code i.e. in this case +34 but that's clearly not what determines whether a call is 'free' or not.
15 REPLIES 15
spraxyt
Resting Legend
Fixes: 75
Re: Just curious - what determines whether international call is charged.
I assume the complete number is checked when working out all charges and calls to the Canaries will include an area code that identifies the destination as being there - so charged.
David
longedge
Fixes: 4
Just idle curiosity really about the exception and why...
Anotherone
Champion
Fixes: 21
If you look at the Home Phone tariff http://www.plus.net/residential/tariffs/homephone.html you'll see that the Top 20 International Fixed & Mobile list (those included in the 300 minutes if you are on the Talk Anytime International 300 tariff) are the ones that are free as long as you have minutes left.in your month's allowance.
But note, it does state "Spain (ex. Canary Islands)". Canary Islands fixed numbers begin 822/828/922/928 AFAIK.
I'm not sure which Mobile operators have a presence in the Canary Islands, all mobile numbers in Spain and the Canaries begin with 6 and 7 but are distributed to each operator dependant on the next two digits.
Also note that currently all chargeable calls are the same rate whatever time they are called, but when the new tariff comes in on 18th November this changes.
There will be separate rates for daytime, evening and weekend, although it looks as though the evening and weekend rates are the same.
Also note that the the Talk Anytime International 300 tariff will have a Top 35 International Fixed & Mobile list of countries (instead of 20) which will include the Canaries.
HTH.
longedge
Fixes: 4
Yes I did say -
Quote from: longedge
My call was to a hotel not a mobile i.e. I called Spain but charging appears to rely on area rather than country code.
BenTrimble
We received details of the call you made in the form of a CDR (call data record). This CDR includes information which tells us which destination you called. We compare this destination to the telephone number called (as a double-check) and if they match, we take the price listed in our database for that destination and work out the call cost based on duration, time of day, etc.
longedge
Fixes: 4
Presumably that's all automated. Seems odd when it's a 'country based' option unless there is an actual additinal cost to PlusNet for some unknown reason.
Anotherone
Champion
Fixes: 21
The Canary Islands are listed as a separate Country. Just because they start with the same code doesn't mean the charges are the same. Depending on where you are calling the next 2 or 3 digits can be significant, and sometimes 4 or 5.
Some providers may charge the same for some Countries that have the same codes, others do not.
Here's another example - take USA, Canada, Bermuda and the Bahamas, they all start with code +1. Whilst charges to USA & Canada are often the same, Bermuda is more expensive and the Bahamas is considerably more.
BenTrimble
@longedge
Indeed, we process hundreds of thousands of calls, every day - I wouldn't like to do that by hand!
The maintenance of the platform, however, sits with me so I make sure that the prices charged are the same as advertised, etc.
longedge
Fixes: 4
Quote from: Anotherone
Whereabouts? I think it's rather more like the separate states of the USA or Germany which like the Canaries are autonomous in some respects but still fall under a Central Government.
longedge
Fixes: 4
Quote from: Ben
Yes that's certainly correct and the 82pence it cost me won't break the bank  Grin
Anotherone
Champion
Fixes: 21
In any Telephone Service Providers price lists. Specifically in Plusnet's that I linked to in reply #3 as your service seems to be provided by Plusnet!
I said they are listed as a separate "country" from the point of view of charging. Some providers will group/include some together.
I'm just providing you with information about how it works, you are splitting hairs. I'm not wasting any more time on this. You don't even seem to be grateful for the information provided  Roll_eyes
longedge
Fixes: 4
Perhaps you didn't read my initial post when I said - " it's quite clear in the list of countries that calls to the Canaries are not included".
I still wonder (and it's nothing more than that) why the calls are excluded.
BenTrimble
Calls are excluded based on wholesale price, usage levels, usage profiling, etc.
longedge
Fixes: 4
If there's an additional wholesale cost then it entirely makes sense that it's passed on. Thanks for the answer Ben.
Just bye the bye, I'm not the first to wonder about this as seen <a href="http://community.bt.com/t5/Phones/Call-charges-to-the-Canary-Islands/td-p/342623">here</a> for example.
