Joining Home Phone
- Home Phone
- Re: Joining Home Phone
Joining Home Phone
25-02-2009 12:53 PM
I am due to change to Option 1 with 10GB at the end of my payment period Feb27th,and I want to join Home Phone Anytime+ I have recieved confirmation from BT that my rolling 12 month contact finished on Feb 20th,what do I do next,I dont want any problems thats why I'm asking first,dont want any OH you should have done this or that,no unforseen payments that I could avoid,any suggestions Please.
Message 1 of 5
(1,390 Views)
4 REPLIES 4
25-02-2009 1:01 PM
Hi Ted,
Your best bet is to put in a product change request after you've moved to Value.
You can keep the same broadband product, you'll just need to request the Home Phone product.
Message 2 of 5
(468 Views)
25-02-2009 1:54 PM
Quote from: Jameseh Your best bet is to put in a product change request after you've moved to Value.
Ted said that he was moving to Option 1.
Message 3 of 5
(468 Views)
25-02-2009 2:10 PM
Apologies.
Same applies.
Same applies.
Message 4 of 5
(468 Views)
25-02-2009 2:47 PM
OK ,thanks James ,will do that as its only a couple of days.TED
Message 5 of 5
(468 Views)
