Jargon busting
- Home Phone
- Jargon busting
Jargon busting
21-01-2013 10:08 PM
Hi. My landline isn't working and this is part of the update I've been provided. What does this mean? Does this mean that it is confirmed that the fault is not my responsibility and I will not have to bear the cost - the £60 call out charge?
[internal]
NDT
Test Result: Fail - Fault located at exchange (Openreach side of MDF)
Description: FAULT - Wiring fault between EvoTAM and legacy linecard.
TR0000002368153
Thanks!
[internal]
NDT
TR0000002368153
Thanks!
Message 1 of 5
(4,572 Views)
4 REPLIES 4
Re: Jargon busting
21-01-2013 11:02 PM
It identifies the fault is at the exchange which is certainly not your responsibility so no risk of being charged on that score.
I know the threat of being charged is always a worry but if you really do the checks Plusnet ask for (rather than just saying you've done them) almost certainly you will have confirmed any faults are not internal to your property so you shouldn't be charged.
David
Message 2 of 5
(1,345 Views)
Re: Jargon busting
22-01-2013 11:18 AM
Thanks!
The only test that I could do was connect my phone. I confirmed the instrument was working by connecting it to a working connection at a neighbour's place. However, the other tests that Plusnet recommended can't be carried out by me because I live in a block of flats.
Hoping that this gets resolved sooner rather than later!
Message 3 of 5
(1,345 Views)
Re: Jargon busting
22-01-2013 4:20 PM
Message 4 of 5
(1,345 Views)
Re: Jargon busting
23-01-2013 8:25 PM
Hi prernakapoor,
Our suppliers believe that they have resolved the fault for you. Please let us know if this is not the case so we can get the issue investigated further
Message 5 of 5
(1,345 Views)
